engine mounts
(In Topic #104323)
engine mounts
ben
ben
best setup in my opinion is poly on the two sides, HD rubber in front and OEM in rear. i hear stories of the poly front mount actually breaking rad supports, never seen it happen though.
Josh
MK1 Search and Rescue Platoon
no sure where to source the poly sides in the UK, but i have a set here and am getting the part # for you: its 22-505, made by Prothane Motion Control, www.prothane.com, barcode is 36169 02211. look 4/5ths of the way down the page in link below and you will see them for 10 US dollars a piece but not sure of postage to the UK. http://store.blackforestindustries.com/enpe1.html
these have to be pressed in, so youll have to pull them and run down to a local shop unless you have a press.
hope this helps!
Josh
