engine mount and starter motor bolts?
(In Topic #204506)
so need a new one cant find the correct bolt available anywhere?
also the 2 bolts going through the starter motor to the front engine mount where both already damaged before i then butchered them further..
i believe they are supposed to be spline head m10 x 135? but one was a hex/allen that came out with an 8mm allen key and the other was literally totally round inside the head so cant tell what it was supposed to be..
any ideas on who has these replacement bolts available i have had a little look about online but with no luck.. the starter motor bolts are 75% smooth shaft with just a short amount of thread at the tip.. could a fully threaded bolt be used?
cheers in advance
1983 mk1 gti white bought as a daily now in pieces..
