engine identification
(In Topic #106591)
Re: engine identification
wussy said
hi im 18 and part way through doing engine change on my 82 formel e i have got a 84 khaman convertible gli i was just wondering what that engine is and is it the same as a mk1 golf gti
84 GLi Convertible will have a 1.8 injection engine, exactly the same as the 1.8 Mk1 GTI.
wussy said
it looks the same as a gti engine bay
It should do! Its more/less exactly the same
wussy said
just the air box and fuel sytem come of the engine and down the passengers side to the battry
Correct - assuming you mean passenger side = left of car. (Assumes RHD)
wussy said
and on all mk1 gti it goes down the drivers side
False - on all standard Mk1 GTI hatchbacks the fuel lines, metering head and airbox are on the left. (On mk2, they have been relocated to the right)
wussy said
this is the first time doin any thing like this and any help want thanks
Are you aware the engine mounts are in a different position? Basically, you have a number of issues to additionally overcome, because you're doing a 'small block' to 'big block' conversion. Top tip:
DON'T BUILD A CAR YOU CAN BUY!!!!!
If you're doing the engine conversion simply because your engine is worn or broken, and you need to swap the engine, then find an equivalent engine eg 1.1 or 1.3 small block (some Polos also came with the same engine so could be donors).
If you're doing it for more power….find a Golf GTI instead, way less hassle. There is a long list of differences of engine and non-engine-related things, which will be important.
infomation
