Engine cutting out sharply
(In Topic #133131)
I presume this is an electrical problem, hence why i posted it here! My engine is cutting out quite sharply at (normally at high revs). It is often accompanied with a bit of a backfire when it kicks back in.
Basically, when driving, suddenly the engine will stop firing, the revs will drop but within seconds it might kick back in. Last night was the worst scenario, i dropped into 4th to overtake, i redlined it and the engine died, it took a good 10 mins of witing for it to come back to life.
Any ideas guys? This is really irritating. I checked all connections to the coil and they seem ok, could it be a fueling issue or should I just replace all HT leads and the coil?
Something like this:
If so, might worth checking it out as if it is cutting out when you red line it, this is what is supposed to happen, however it sounds like the return spring is not working for you, sticking maybe, causing a permanent short to earth.
If you have a rotor arm without a limiter on it, try that…
My Build Thread
Ill try and get my hands on a rotor arm without a rev limiter and give it a go!
Member 125 - 2005
Its probably dirty fuel, the high speed/high acceleration caused a blockage somewhere which reduced fuel pressure and caused the poor running, which eventually unblocked itself and cleared.
Very common problem with Mk1s!
This is getting quite frustrating, can anybody point me in the direction of how to eliminate the block? Should i try a fuel additave to try de-coke it first?
