Engine conversion into an AUTO clipper has anyone done it
(In Topic #163317)
1.8 turbo conversion into an auto clipper ?
I'm looking for a cabby and whilst reseaching I've realised that a lot of clippers are Carb (although I'm looking for small bumper GTI)
My question is how easy is it to fit a late 90 spec GTI engine & gearbox plus dig injection system in?? reason is I scrapped my late mk2 but kept eng, gearbox, airbox and complete wiring loom
then you'll have to add the fuel pump wiring which is either a case of get one from a gti or add a pin to the fusebox plug E pin 14.
next up you need to give it fuel, since its a digi engien no need to run the k-jet high pressure stuff rubber fuel injection hose will do (id go with overbraid for extra protection) you never know the mk2 pipes may fit even? then you'll need a post-84 cab, rocco or g40 shape polo lifter pump and fuel reservoir and finally a main pump. options for that are polo gt or g40, or any mk1 injection with an m12x1.5 barbed 7-8mm adaptor threaded on the end.
exhaust wise mk1 1.6-1.8 all work but try to get a proper 6 bolt flange gti manifold and downpipe as they flow better
rubjonny said
pretty simple really, shame its a 90spec though as if it was pre-90 the loom would plug into the fusebox you woudl just need to tweak the lengths a bit. but tbh its not hard really as the mk2 ecu loom splits off from the bay loom, you just need to feed the 5 pin plug in the bay with what it needs so cut that out of the old MK2 loom and add it into the cabrio loom once you buy it.
Many thanks for this info
I saved everything from the mk2 even the 6x bolt exhaust and manifold
Looking at a couple of cabby's tomorrow and all are GTI's
Looks like I might have a nice winter project on the way with an engine rebuild and swap
my mk1 cabby 16v had a custom downpipe i found off the bay of e, pics in my thread:
View topic: Project 83 MK1 cabby, several years in the making! - The Mk1 Golf Owners Club
