Engine conked out and water spurting?
(In Topic #138523)
The car has been stood for around 2 years now and have just got it running, topped the coolant up and started fine, left it running for about 5 mins then it stated sluttering and conked out, water then poured back out of the coolant tank as I had left the lid off to make sure no air was trapped. Could trapped air be the likely cause or is it H/G there is a small amount of gunge in the oil cap but not a lot so put that down to condensation, any advice welcome.
Well, I'd just top it up with water and keep going, until no more air comes out and the level has settled down to a constant. Air (bubbles) can & do come up, but not normally vigourously enough to spill out of the expansion tank, if the car is idling.
The fact that it conked out is a separate issue, but with it not been run for 2 years it will definitely need a tune up etc.
the water will boil if you leave it long enough, keep an eye and switch the engien off and fit cap when you see the water start to rise/boil
