DX Vacuum switches between dizzy and throttle body
(In Topic #219964)
Hi
Does anyone know if the switches and parts 19-22 are used on a 1983 DX engine, or what they are for? It's going into a 1976 car without the MFA and such, would they still be needed? Any input is helpful
Early 77 year model Golf. 4-Door
They are for the MPG reading on the MFA in early cars so not needed, later cars did not have this set up, they still had a pipe from the dissy to the back of the throttle body to advance the timing.
Superb, many thanks.
Over here it was used to power the up shift light for folks that needed to know when to shift gear efficiently to increase the MPG of the car because they were either too stupid to know, or a novice at a manual transmission.
I can remember when it was touted as a greatest feature there was…. .From a Salesman as I was waiting on my car to be serviced…
I think Briano1234 is right and I'm wrong on the MPG part but it's no real use to you so don't worry trying to find parts…
They are still avail 171-919-825B . for those that want their upshift light to work, that is if it works in the clusters…. is it needed? Not to me, as I know how to shift, and well the 90's didn't have it and how it is supposed to work on a diesel that doesn't really have a vacuum system on the engine.
Well money saved for me, I am keeping the original '76 dash cluster. Funny about it being a great selling point back in the day…
The vac switch mentioned on the dizzy to throttle body vac line is there to switch off the up shift light when your in gears 1 to 4 and have taken your foot fully off the throttle pedal. That vac line has no vaccum in it when the throttle is fully shut. If you didn't monitor that line then you would have the upshift light on during over run/ engine braking which would confuse even more.
