Difference between Mk1 1800 and Mk2 1800
(In Topic #75857)
What are the differences between the DX and the mk2 1800 K-jet?? Would my inlet and exhaust manifolds fit on to it?? If it's an easy fit I will probably go for it!
Anthony.
engine
Beware of the injectors though as the Mk2 ones are slightly different and require little hats on the end with a second seal. My engine seems to have a Mk2 head on it as it has these injectors and the outlet pipe, though I'm not sure if the block was originally Mk1 or 2!
If the engine has the injectors/k-jet system with it, you may need to utilise some of these bits.
My Build Thread
I think that their are different spigots for waterways between the Mk1 1600 and 1800, but I think that these are common between MK1 and MK2 1800's?
I have a MK2 1800 in my Mk1 and I basically changed all of the above. I had three of four engines to take parts from though! - be warned!
Shonky
'82 Mk1 GTI 1870 160bhp
'83 Mk1 GTI 1800 (Now deceased)
'80 Mk1 GTI 1600 (Now deceased)
'81 Mk1 Golf 'C' 1093 (Long-Awaiting racecar transformation)
Audi A8 Sport (Gone but not forgotten)
Toyota MR2 MK1
Toyota MR2 MK1
