Crankshaft pulley removal
(In Topic #145555)
After I removed the 4x hex screws does any one how to remove the crankshaft pulley, I've seen videos of having to remove the nut on the end and other posts saying not to.
The engine is still in the car so it's a bit tight for space.
On previous cars I have used a breaker bar and help from the starter motor to remove the crankshaft nut.
J
J
dont undo the middle bolt, that is only if you need to remove the sprocket. for the pulley you might need a set of pullers to get it off if its well siezed, but try tappign it lightly with a hammer that might crack it loose
Thanks John, I'll give it a try tonight.
