Crank and con rod dimentions?
(In Topic #110006)
Hey can anybody tell me the dimentions on a standard 1.8 gti engine, the crank throw (from center of crank to the center of the big end) and the length of the con rod (from center of big end to center of little end)
Help will be greatly apriciated.
Mk1 Golf Gti Abf conversion Project
Mk2 Golf Gti 16v
Mini Cooper S R53 (Daily)
Perfect! thanks alot mate
Mk2 Golf Gti 16v
Is there an equivalent for the 1.6 (EG) engine? Or does anyone have the data to hand?
Rich
Rich
Rich
the other equivalents for the 1.6eg are the carb engines… same stroke same bore diferent compression
for engine codes check
http://www.doppel-wobber.de/wbb2/Information_79_VW-Golf-Motoren.html
mihnea
Monsieur, with this data you are truly spoiling us :y:
Thanks!
Rich
Thanks!
Rich
LOL… don't know why but that got me laughing :wink:
it was a pleasure to help. i didn't think that you don;t know this site. it is full of info…. use a google translate if you have problems with german
I had loads of problems locating the correct shells from my local parts place. I told them I need bearings for my 1.8 MK1 Golf and the sent me bearings with no tags. I have been told that these are for the 1.8 20v that have cracked conrods. In the end I spoke to a specialist engine parts supplier up north http://www.lymmengineparts.co.uk. They knew exactly what I needed. I should have know that my factor would get wrong when they asked me how many balls were in my bearing!?!?!
Old school engine rebuilders are great at finding parts and info, I took my head to one and they could sorce all the bits I needed for a 1978 head.
