Correct torque for rocker cover nuts?
(In Topic #73566)
Was thinking it might be time to invest in a torque wrench.
Is there a specified torque for the 8 nuts?
Peter.
1980 1600 GTI, daily driver.
Of course you could just tighten by hand in which case they need to be about so tight :wink:
1983 1100 C
1983 1100 C
Just do the buggers up "so" tight as Markwon said…
My Build Thread
My Build Thread
Turns out when I took it off I also loosened one of the studs slightly and didn't notice so that's why it leaked!
I bought a torque wrench, 10Nm is about 7lbft as markone says.
Never used a torque wrench before so that was fun.
Without a wrench, It's bascially tighten them until you feel resistance, then about a quarter of a turn.
…with a wrench it's click.
Peter.
I have two torque wrenches, a large Clarke one that I rarely use and a smaller low range Halfords Pro one which was less than 50 quid. The Halfords pro low range one is the one I use 90% of the time and it has a really nice twist grip lock setting and easy to read scale. Lifetime warranty, 5-60 Nm range and comes with a calibration cert too - buy one you won't regret it…..
Chris
I have a small pool of oil develops on top of the inlet manifold between cylinders 1 and 2. I don't think the nuts for the cam cover are too loose but assume this is the only place the oil can be leaking from? :dontknow:
Perhaps I twisted the gasket or something but I really think it was straight!
small pool
I had a piggin lake yesterday. It smoked like a good un aswell and I couldn't remember if engine oil could catch fire?
Peter.
I remember the teacher (was a bit of an idiot!) waving a bunsen burner flame over a tray of oil and commenting how it 'doesn't catch fire' However, a few minutes later it blew up in his face!
