correct procedure to start-up the 1.8 KJet
(In Topic #95760)
This is the procedure.
1_press the accelerator all the way down
2_release the pedal
3_press the pedal half way and keep it in this position
4_start-up the engine while keeping the pedal half way.
Is it normal or is it a symptom of something getting bad?
Ben
Golf Cabrio 1.8 GTI Quartett, 1989, Helios Blue.
Land Rover Defender MY 2007, Carintia Blue
FIAT 600, 1954, grey
FIAT Panda 4x4 Climbing, 2009, Bianco Bianco
http://homepage.mac.com/bengi/PhotoAlbum36.html
paul_c said
The K-Jet is designed to start hot or cold, simply by turning the key (no pressing of the throttle required). However it doesn't always work out like that once it wears. Pressing the throttle half way down during startup, to make it start, sounds like flooding.
If I simply turn the key, no throttle, the car starts up flawlessly and the idle is at a steady 800 rpm. The weird thing is that for the very first two min, especially if outside it is very cold, it runs rough below 2000 rpm.
Ben
