converting from injection to carbs
(In Topic #122896)
cheers for any help
Tom
Im sure theyd advise on sizes for a starting point.
Only way to determine what your particular engine needs is a dyno session.
Original injection pump and accumulator systems way too powerful, you need around 4 to 6 psi iirc to run 40's rather than the 60 or so psi youll get from the injection pump.
There is however a regulator you can likely get from webcon that will allow you to retain the injection pump whilst running the webers, that way you avoid any electrical changes.
Tom
32mm chokes
4.5mm aux venturi
120 main jets
f16 emulsion tubes
220 air correctors
45 f8 idle jets
32mm chokes.
4.5 aux venturi
main jet 135.
idle jet- 0.55 f17
emulsion tube f34
air corrector 2.10
starter jet 0.85 f9
accelerator pump jet 0.35
accelerator pump back bleed 0.60
needle valve 1.50
all for an 1800 alfetta tho and may be closer but definitely time for some dyno time to get them set up.
