Cold start teaser
(In Topic #94236)
Cold start teaser
The motor in question is a 1.6 K-jet, fitted with a Turbo Technics (Dr Schrick) conversion, otherwise standard. I've had the car from new (39,000 miles) and put it to bed 7 years ago. On wake up, last year the probelm appeared.
The usual culprits have since been dealt with: corroded filler neck renewed; tank put through the "renu" process (full of rust), new fuel pump, new fuel supply and return lines, new filters (in-tank and at engine). Accumulator has not been changed. All cold start equipment (WUR, AAV, CSV, TTS) has been checked by a local specialist I was put in touch with - OK there. He tried a spare metering head which did not solve the problem. Fuel pressure is apparently slightly low (copper fuels lines probably have a slightly smaller ID than the steel originals) but not enough to cause problems (witness the OK-when-warm situation).
When by-passing the turbo (connecting the metering head directly to the throttle body) the problem disappears.
So I am still facing a dilemma. Is it possible that faulty vaccuum pipework may be preventing cold running?
Any suggestions from anyone (other than throw the turbo away?
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
Re: Cold start teaser
not really, so throw the turbo, along with manifold and if you feel generous, any associated parts, my way please.
sim0n_parker said
seal gone in the turbo? all pipework tight?
be my first point of call too.
