Cold Start Issue 1.8 8v K-Jet DX Engine Code
(In Topic #87816)
I have had some real problems with my 1.8 8v K-Jet running from cold. Once started the engine would sound choked & run at low revs, then stall. Once this process is repeated 4 if not 5 times the egine would warm & run as sweet as a nut!!!! GRRR
Have read around and found the main areas of concern to be the 5th Injector or Warm Up Regulator.
I have replaced the 5th Injector….no change
I unplugged the warm up reg & the car started easily & run smoothly….does this mean it is broken or is there something else at fault???
Also having problems with fuel pump relay number 62…the fuel pump keeps cutting out, I hear relay No 2 could be used??
Anyone got any spares???
Cheers in adance for any thoughts, tips or suggestions on how to test components
