Cold start and temp issues!!!!
(In Topic #104661)
cold start issue:-
having simular cold start issues to rossirvine who recently posted but instead of not reving for 5 secs i can do cold start procedure foot on acc befor turn over fires up then dies but keep foot down once started cpl of secs settles down…..then once warm if turn car off and fire up takes a while to start up have to keep foot planted on a warm start? cant be right can it, once warm should be able to just turn car over with out planting acc?
temp issue:-
what temp should oil and water be at
oil on dig read out is about 108-114 on idle once up to temp? is that rite
once rolling on road drops to about 100
water temp on dial is running just over ( a needles width ) the led temp warning light?
temp issue:-
i believe 100 degrees is about right for a warm 8v, 110-120 for a 16v.
as for coolant temp, it should run overtop the light so that sounds good too.
your starting problems sound like fuel delivery or mixture. probably mixture since it runs out good once started.
thats my .02 worth.
thats my .02 worth.
Josh
MK1 Search and Rescue Platoon
