Cleaning out the fuel system
(In Topic #201005)
Engine stutters after a drive, only when stationary
Has anyone ever cleaned out the fuel system for their Mk1?
Mine's an injection model, Clipper Cabrio '88.
Replaced the fuel filter but only helped for a little while. most obvious would be the fuel pump is struggling to get fuel to the engine, which means it's blocked most likely.
I'll run engine cleaner through and check the fuel filter afterwards but ideally I'd like to clean out the entire fuel system.
Thanks in advance,
Gordon.
They are cheap and easy to get to.
Your car can't be a clipper as they came with a carburettor ?
You do have the fuel injection system if so it's a GTi?
I'm going to take out the fuel filter first as it's easy, rust might be the answer though as there is a small crack at the top of the fuel tank..
How do I get to the lift pump? I was going to check the fuel accumulator too. Is it necessary to take the fuel pump out and clean it?
It's a 1988 Karmann. One of the first injection clipper kit Mk1's I believe.
Thanks for the responses guys. Just trying to figure out ways to check the fuel system without taking everything off!
If you look at the bottom of my project thread you can see how I got a tin top filler neck to fit or you can buy a cabriolet one but they are pricey.
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fmy-daily-drive-1988-gti&kfs79=30
To get to the lift pump remove it's under the base of the back seat under a black cover. I'll try and find a link save me typing it all out again.
Found this…
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=big-block-injection_2%2Fwonder-if-you-guys-can#post_1345240
If you have a metal top on the lift pump/sender like mine (some are plastic) you need turn it about 45 degrees to remove it, it's like a bayonet connection I use a flat bit of metal to tap it around to undo it. It is an art getting it out as there is the fuel tank level float attached and a pump so there not alot of room to get it out but it is possible just go carefully.
Last edit: by mark1gls
View topic: Fuel Tank cleaning *HowTo* clear that blockage - The Mk1 Golf Owners Club
You can see the filter in this link to a new lift pump.
http://www.ebay.co.uk/itm/VW-GOLF-MK1-CABRIOLET-MK2-GTI-8v-16v-FUEL-PUMP-LIFT-PUMP-IN-TANK-C246-/200691149226?fits=Model%3AGolf&hash=item2eba1fe9aa:g:VV4AAOSwMzVTw6~7
1) I'll get some pics of the tank and the neck filler to see for any damage.
2) I'll take the fuel filter out and see how bad it is, although it's fairly new so I don't think this is the problem.
3) If no damage to tank or neck filler, and the fuel filter seems fine then I'll disconnect the fuel pipe from the accumulator to the fuel pump and turn the engine over.
Am I right in thinking that if some not very nice gunk spills out of the fuel pump then I've found my problem?
After this my knowledge on this ends.
nb. What can I use to clean out the fuel lines?
ps. the job you did on our GTI is awesome!
On my cars I started with dropping the back axle and removing the tank and always ended up changing it due to internal and external surface rust.
The tank is probably 27/28 years old now…
That is if your car primes the pumps with ignition, if not just swap the 18 relay into slot 2 this will make the fuel pumps come on constant with the ignition so you can listen out for the lifter pump
