Can only start with a 'jump' plus other problems
(In Topic #154636)
At the moment I can only start the car with a 'jump' start. The battery is showing as full when I put it on a charger so I guess this is not the problem. This has been going on for a few weeks but is gradually getting worse, usually a half hour blast around is enough to let mew switch off and restart OK, yesterday this also didn't work and I was let stranded in a petrol station (luckily the wife came out to rescue me - meant I owed her a favour though and ended up missing the FA Cup Semi on TV as I had to play taxi up and down the M4 for my eldest and her mate)
Additionally pre 'jump' there is also zero power to the car, lights, radio the lot, not just that the engine won't turn over.
Also, when I did get going yesterday I noticed the VDO oil pressure gauge was all over the place, up and down like a tarts draws - its not done that before (well not since I fitted the gauges a couple of months ago)
The oil temp and volts were both steady just not the pressue ??
Finally, the engine temp gauge is showing as hot, it gets hot quickly and then stays that way, virtually up to max, I also topped up the water and coolant as these seemd low yesterday but still the dial was way over to the right. So far I've had changed, thermostat, radiator, head gasket with NO luck - Any ideas ?? I must admit the wiring looks like it was previously worked on by David Blunkett and Stevie Wonder so this may not be helping the problems……. HELP please
MOT and TAX due in the next couple of weeks so need to have these sorted
cf_emoticons__BangHead: cf_emoticons__BangHead:
or maybe an old immobiliser tucked away under the dash. I had a hot start issue once discovered lots of old imobiliser bits and wiring stripped it all out and never had an issue since.
If you connect the battery to the starter with the ignition on it may start that way, use a good thick wire or jumper cable. That may help you to tell if its a starter problem or switch ignition related.
Last edit: by pearcestu
I'll give it a go and see what happens.
Turns out the battery was deffective so luckily as I got the old battery from the RAC it was changed for FREE as it was still under warranty.
Bad news is the starter motor is knackerred - does anybody know what is the correct STARTER MOTOR for a 1989 8v GTI cab (DX)
1987 Caddy 1.6Turbo Diesel-GTD
Instagram: Cavscp
Instagram: Cavscp
