cam timing
(In Topic #73157)
cam timing
Thank you
Life Member
I find doing it this way easier because the timing mark that Haynes suggests can be miles out!
HTH
Nick..
MK1 Golf GTI 1900
MK2 Jetta GTI 16V
MK2 Jetta GTI 16V
I am just about to swap my fast road cam out for a standard item. SHould it just be a straight swap (assuming I don't disturb the relative position of the pulleys)? Or would there be some timing adjustments needed going back to a standard profile cam?
Cheers,
Chris
to my knowledge TDC is found by aligning the mark on the crank pully with the mark on the pully for the the distributor. will be neccesary to remove cam belt covers and then replace the alternator pully back on to the crank
It is always better to use a vernier pulley to make sure you are spot on with the cam timing, especially if the head has been skimmed but you can do without . It is a must on a flowed head though, to get the best from it.
MK1 Golf GTI 1900
MK2 Jetta GTI 16V
MK2 Jetta GTI 16V
mattgti said
This may be a bit of a dim question but is there a specific stroke im looking for TDC on, as mine is still not firing (has good spark, fuel etc.)
Yes, every second stroke of the piston is when it doesn't fire (scavenge stroke), which is used to drive the exhaust out of the cylinder.
The way to discover which stroke of cylinder 1 is TDC and not the other (scavenge) stroke is to look at the cam lobes (cam-cover off). Bring the piston to the top, and ensure that the two lobes for no.1 are pointing upwards (like ten-to-two on a clock-face) - if not, wind the crank round one more time, and you'll be at TDC.
I can't recall seeing one on the inside. Will have a look. The one on the outside is miles out.
Type17 said
The reason that there are two marks is that this wheel is also used on the intemediate shaft, where it needs an outside mark to line up with the crank pulley, but it's a confusing ecomony too far, in my opinion…
arrhh that explains it then :roll:
Now you've found it, put some white touch-up on the timing mark (same for t'other's if you haven't covered them up! (ignoring the dummy mark on the outside of the cam pulley of course)
Mk1 GTI
B5 Passat Estate 5 SPeed
Bosch Lawnraker 32
Bosch Lawnraker 32
