Cam Shaft Tapping
(In Topic #195396)
Any help appreciated.
All the best, Adrian
- 1986 Mk1 Golf GTi Convertible
- 1974 Mk3 Jensen Interceptor
What's the mileage on the car?
Mine lasts anything up to two minutes from a cold start, depending on how cold it is over here. It's a 1990 with 57,000 miles.
From cold, let the engine come up naturally to normal operating temperature and stand there so you can listen.
You might just find the noise fades as the temperature comes up.
Your friend may well be right but I'd rather do that first then start ripping the engine apart!
How old is your oil and what grade of oil are you using?
first up check the filter, if it doesnt say MANN and/or have any vw marking on give it a service with fresh oil and proper filter:
AVS Car Parts - [The VW - Audi - Seat - Skoda Parts Specialist]
I use quantum synta silver or fuchs titan xtr 10w40 on all my dubs and this does the trick nicely, but most semi-synth 10w40 will do you just as well tbh
