cam belt change guidance
(In Topic #86671)
Hi Folks
I have a 1980 GLi Cabriolet and would like to change the cambelt. I've searched the forums but obviously each search brings up many results. I'm not sure if there's a definitive guide on the site but if there is could someone point me in the right direction ? Thank-you.
Try a suitable Haynes manual for a step by step guide with pictures. Failing that I'm sure someone here can help.
Mk1 GTi White Cab '86
Mk4 TDi
Mk4 TDi
Yes Thanks Dannyboy but I've had a look and it seems the guidance in my Haynes manual is contained within the section on a complete strip down and rebuild, I was after a more concise guide plus any tips concerning tools etc
Haynes does provide good info, but you ned to pick out the parts. Removing cambelt is in the strip down section and refittiing is toward the end of the rebuild bit. Alternatively have a look at this on big block timing belt renewal.
1983 1100 C
1983 1100 C
can you give me your engine code and I will get you a how to guide for removal and refit of belt
Engine code should be on vin plate
Craig
Craig
Touch my car …………………. feel my wheels
operor retineo patria parvulus depressus vos
engine code wont matter, all big block 1800, 1600 8 valves are exactly the same in timing marks etc,
if you are stuck i could get my timing belt book scannd in n email it to u? simon
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
sorry I thought that there were some slight differences and also that there are two different timing mark setups on the camshaft sprocket one front to the top or one to the rear which should sit at about 3o'clock
Thanks for all the help - looking at the haynes manual I think I've picked the bones out of it and I will fit a new tensioner too. Did I read somewhere that deep sockets are needed for the lower cam belt cover
Just looked at the link posted here too, thank you all for being so helpful !!
