Cabby running funky
(In Topic #108466)
Cabby running funky
Problem is up to 3.5 k the car judders, over 3.5k smooths out and pulls like a train.
When I say judders the revs stay stable etc it dosn't cut out etc?
Any ideas?
Engine?
K-Jet?
Is it only when cold? warm?
How does it start?
Hot or cold, same issue, when starting from cold it's a pig but when it's warm it fires straight up.
But still judders?
Just fitted dizzy cap and rotor arm, no change, can't do the timing as the dizzy has welded it's self to the block.
Exhast smells a bit of fuel, no smoke and occasional misfire?
It could sound like it it running to rich?!
Turn the mixture a little anti clockwise to make it run leaner. It is very sensitive. 1/8 turn could be enough.
It is a 3mm Allen (hex) and be careful as it is a sensitive part of the engine.
Tak a look at the "Fuel Injection" link under "Technical" to the left of this post…
Running Funky
P.S Engine is 1.8 GTI, DX.
Cabby running funky
Going to set the co up and throw some injection cleaner in the tank, then run it!
Also fixed a broken wire to the 5th injector which might explain the crappy cold start?
which hose did you have to change?
Joe
Black 1992 gti cabrio sportline
