broke down!!
(In Topic #85844)
broke down!!
Did the engine cut out at speed or did you just lose power? Anything leaking? Have you got petrol in the tank?
Need more info!
Danny
Mk1 GTi White Cab '86
Mk4 TDi
Mk4 TDi
Mark.
Web Team
MRBLONDE said
nah it just cutout,just turns over.i can hear the pump.im thinking it could the fuel pump relay??..get one 2moz.fingers crossed!
If you can hear the fuel pump running then the fuel pump relay is working.
mr blonde, if it just cut out all of a sudden and now only turns without firing, then it is most likely electrical. very probable that it is from beetween the dizzy cap and the tci unit.
i always check the fuses anyway. force of habit.
take off the dizzy cap and check inside. could be the carbon bit in the middle of the cap has broken. not unusual. check the rotor arm too. not much to go wrong with these mind.
check the ht lead from the cap to the coil. make sure connections are o.k. and no breaks.nicks in the lead.
next coil. check the connections are on o.k. first, then see if you can swap a coil just to check it.
last but not least the tci. again see if you can swap one to check it.
one of these are most likely to be the problem.
very much undefinate though
Do all the easy stuff first:
Spark at plugs
Spark at king lead
Fuel Delivery
Then do the details stuff…
The TCI might have gone duff - I have good used items
or wiring, coil, king lead, cap, hall sender
do check to see if you have a spark first. before you replace anything else
