Attempt no.2
(In Topic #73760)
Attempt no.2
anyway, while lifting the manifold out I noticed I had forgotten to put a little pipe on the back of the throttle housing which goes to the vacuum unit on the side of the distributor… would this pipe stop the car from idling? anyone wanna try pulling it off and see if they're car idles?
my thought is that there's an air leak in the system which is stopping the sender plate from lifting in turn stopping the fuel to the injector's
There are plenty more places to have an air leak though. They can be quite hard to trace!
My Build Thread
hopefully the new gasket will help things out
will see if the gasket improves things.. and I MUST do some fuel quantity checks!
goes to the back of the throttle housing?
on my car it goes here…
and it screws my idle right up when i take it off!
HELP!!!
PICS COURTESY OF WALT
My Build Thread
Presuming you dont have a single vacuam advance on your dizzy, you should have two pipes, one as you have stated and one to the back of the throttle body.
1982 Mk1 GTI 16v Mars
1978 Mk1 GTI 1.6 Mars
1975 Mk1 LS
1996 Mk3 Cab VR6 Turbo Project
1998 6n Polo Black
1984 UR Quattro Red
1961 Lotus Elite Silver
Mk1 & 16v Golf's Breaking for spares
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
1980 1600 GTI, daily driver.
but it does idle when you take it off moreno?
once I've got the new manifold gasket on I'll make sure this is connected.. got to wait a week though :cry:
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
I'll let you know if this sorts it all out!… had better get that Passenger door flat and sprayed to! be up for an MOT before too long :cheer:
i got my mot soon too bit worried but shouldnt be too much of a problem (no rust)
I think you may have sorted my problem with idling in this thread so thank you very much
Steve
now I'm not getting ANY fuel at all, not even to the filter, and the fuel pump isn't really working very well!! , so I've ordered up a new Fuel pump and filter, going to rewire the pump to… but good news is I may be driving a Mk1 sooner than I thought as I may well be getting another one this week
