Are 1.6 and 1.8 water pumps the same?
(In Topic #207920)
As per the title, I'm wondering if the 1.8 water pump I have to hand is suitable for my 1.6?
Both engines are GTI (i.e. DX and EG codes).
Rich
Rich
Yep same water pump.
make sure you fit a new rubber O ring between the water pump and engine block and give the engine block face a good clean.
Thanks very much.
Can you still get the o-ring from VW? If not where's the best place to get one?
I also found a brand new complete pump on Euro Car Parts for ~£30 - are they any good?
Rich
Rich
I think the o ring is the same size as the thermostat but a new water pump will come with 1 new o ring but you will need another one for the thermostat but if are fitting a new one which I would recommend you will get another new with that. Maybe worth buying a spare as they are only 27p!
Car parts 4 less are euro car parts sister company.
http://www.carparts4less.co.uk/cp4l/c/Volkswagen_Golf+Cabriolet_1.8_1989/p/car-parts/car-cooling-parts-and-car-heating/cooling/thermostat-housings-gasket/?369440050&1&63330f5c9c8404a88d323f4ea14e6a2b06173c26&000574
http://www.carparts4less.co.uk/water-pump-gasket
buy the whole water pump not the 1/2 ones as you will find the bolts holding the 2 parts will properly shear off or round off when trying to take the old one apart and they can be a pain to seal properly.
The only difference I can think of is the pulley fitting the water pump? They might be different but not sure??
I've been using a Circoli water pump for about 12 months and it's been fine.
Thermostat
http://www.carparts4less.co.uk/cp4l/c/Volkswagen_Golf_1.6_1979/p/car-parts/car-cooling-parts-and-car-heating/cooling/car-thermostat/?209330080&1&de4f2bfe03cb0f8b338d0c5cfd1ed2b6cf95843f&000325
New ready mixed coolant I use, 5l is enough.
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.8_1989/p/car-accessories/engine-oils-and-car-fluids/antifreeze-and-screenwash/blue-antifreeze/?523770501&0&cc5_865
Edit….. Just noticed euro car parts has yet another sale, 25% off with code SALE25 so it may work out cheaper there than car parts 4 less?
Thermostat
Last edit: by mark1gls
Awesome - I can definitely afford to throw 27p at this problem! Thanks again for all that very useful information…
Rich
Rich
