Another timing question
(In Topic #73645)
I have never had this problem before and it has got me stumped.
When i check the timing on my car (1.6GTI) the mark on the pulley is blurred, instead of the usual plain white line.
What would cause this?
1982 Mk1 GTI 16v Mars
1978 Mk1 GTI 1.6 Mars
1975 Mk1 LS
1996 Mk3 Cab VR6 Turbo Project
1998 6n Polo Black
1984 UR Quattro Red
1961 Lotus Elite Silver
Mk1 & 16v Golf's Breaking for spares
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
Maybe i should try that, i was timing of the end pulley.
Can you see the flywheel though? I have set the timing using the flywheel mark initially when i swapped the distributer but then i used the end pulley to adjust to.
I'm sure it means something is fooked when the timing marks appear blurred though.
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
crazyquiff said
maybe hall sensor
I thought it could have been that, i will check it with the flywheel tonight.
The engine is probably a little tired as my Girlfriend ran it low on oil………and i've been running it with quite a lot of advance, goes like a rocket but pinks and overruns when you turn it off when hot ops:
I have a 1900 block with new pistons that i think i will put in it this winter.
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
Crazyquiff - Many thanks for your help, the timing was, oh, around 10 degrees out!!
Lesson learnt
Lesson learnt
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
