Am I wasting my time?!
(In Topic #133552)
Could some one have a look at the following pictures and let me know.
The only wires coming off of my gearbox is a 2 pin plug. I thought the Mfa would have more?
If someone could let me know, that'd be great. I can stop scratching my head trying to make my mpg etc work!
Mk1 Gti Cabby project on the go! Detailed engine, roof off, leather interior, 16's, painted, now getting put back together!
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=103263&start=0&postdays=0&postorder=asc
im no expert either
but i don't think this is correct box for a car fitted with MFA in saying that all the MFA box has that's extra is a switch wire back to the MFA to trigger the MPG analogue gauge when its in fifth.
this should help
Reverse Wiring
baz
if its a later car without the big mpg gauge then you dont need the multi plug switch, so an easier way would be to just fit a later dash cluster to work around the issue.
other problem is the 1/2 switch, if its a later cluster the switch is on the stalk not the dash, and you need an extra bit of wiring from the switch to the dash. the plug you need is the same as a VW speaker plug, or what you see on the mk2 handbrake and heater light plug amongst others.
if its earlier dash the 1/2 switch is on the cluster and so you dont need any extra wiring.
Just tested all connections and stalk…all fine.
Looks like my dash is buggered!
Anyone have a working mk1 dash with MAF (1990 h GTI cabiolet)????
If I don't have any joy I'll put in a mk2 but would prefer to keep it original.
Can anyone help?
Thanks for all of your advice!
