alternator bracket problem. HELP
(In Topic #142690)
Social Media Manager
the engine i got came with no alternator, so i thought i use my current one which is is perfect working order.
iv got 3 alternator brackets but none of them fit right……
the head with part number
bracket 1 (space at the head end)
bracket 2 has a washer (space at the head end)
iv also fitted this bracket which was on my old engine but still problems
bracket 1
bracket 2
bracket 3
now…. iv got another alternator, but dont know if it works. i put it against my new alternator and noticed the thickness of metal where the bolt goes through…….and then i lined it up with bracket 2 which came with the engine and its perfect for old alternator.
SO…..does any1 know which bracket i need?
………do i use old alternator?
………do i grind some metal of the new alternator to make fit?
I had 2 brackets for the alternator.
Looks like you have the bent bracket the wrong way around?
Here's some pics. Hope they help you work it out?
Gods luck mate!
Mk1 Gti Cabby project on the go! Detailed engine, roof off, leather interior, 16's, painted, now getting put back together!
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=103263&start=0&postdays=0&postorder=asc
"djrussf1" Your just showing off your nice clean engine with those pics arnt you!
Domma……………
