air flow sensor
(In Topic #116634)
air flow sensor
….the plate will lift as the engine draws in air….BUT YOU WONT SEE IT DOING THIS as the black induction pipe (between the metering head and intake manifold) is in the way……..with the car running and the pipe removed you should be able to lift the plate (use sticky tape) to alter the fuel flow to the injectors, but the injectors would have to be removed and placed in bottles to see this…
see my Injector test pdf
mavster said
i can see air flap dropping as i have removed induction pipe to view it, . . . have adjusted clip to set plate at its starting position but every time i turn her over i can see fuel line from tank move slightly and at same time air plate drops down onto the rubber stop
If I understand what you wrote here you are getting the results you should for what you have done, and it will not start by doing that either. You can not remove any of the intake induction piping and still have the engine start and run. The whole CIS system is dependent on two things, air lifting the sensor plate for mixture and fuel pressure. By removing any of the induction plumbing you allow air to enter the engine without first passing (lifting) the sensor plate. That results in no fuel and no therefore start. It is next to impossible to operate the sensor plate by hand and run the engine. You can start the engine this way but you and your hand can not move the plate as required for a correct mixture to stay running (maybe by luck once in a thousand times).
What is happening and you are seeing is this: Sensor plate is adjusted with the spring for correct height, ignition is switched on (pump runs) and builds system pressure, pressure pushes on the top of the mixture plunger in the fuel distributor and because no air is rushing past the sensor plate to lift it it is forced down onto the rubber stop. Do your troubleshooting with the induction system closed and air tight.
you are a star, how stupid do i feel now ? why oh why have i not seen this before ? thanks very much for advice, i am going to try again later and if she fires up rest assured i'll be digging out my dunce's cap and standing in a corner for the rest of the day!! once again fingers, many many thanks.
