Aftermarket oil pump advice
(In Topic #217061)
Brands available ?
Hi all
Need an oil pump for a 9A 2.0 16v rebuild (OE part number 051115105A), want the best quality I can find but unsure of which (if any) brands to avoid, managed to find a Kolbenschmidt, a Meyle and a Topran, been reading good and bad things about all so a little confused, had a search here but couldn't find anything regarding oil pump brands, any help appreciated.
Si
Si
83 Candy White Campaign http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fmk1-golf-restoration_2 89 Caddy pick up http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-other-cars-and_2%2Fcaddy-barn-find Mk1 Scirocco project completed
When I redid my oil pumps on my 1.8 digis, I went with the 36mm gears out of the 2.0 L engines, it have a greater oil flow and a higher oil pressure. I do believe that they were Meyle, and haven't had any issues with them.
On the earlier models you have to use longer bolts to bolt them on from what I hear and I found that the 1.8 36mm pick up tube prevented the oil pan from seating. So I changed the pickup tube back over to the older 32mm geared pumps. Quick easy, and better life to a engine IMHO.
Cheers for the reply, bit subjective I guess when you ask "which one's best", just wondered if anyone knew anything to avoid concerning build quality, used Meyle parts a lot but not their oil pumps.
Ta
Si
Ta
Si
I'd go KS out of those options every time…or Febi….not always available though.
www.jmrclubsport.com
Cheers , that's what I opted for, 👍
