Advice needed on timing on dx 1.8 k jet golf gti
(In Topic #208795)
Cabriolet
Sent from my D5803 using Tapatalk
Hi there have recently replaced cam belt that side of its all ok
Want to find out a little more information on using my timing light as a lot of my manuals say conflicting stuff on degrees and the vacuum pipe on or off
I have a 1992 golf cabriolet 1.8 gti bosch kjet manual transmission. With I think a transistorised distributor.
I have found the tdc mark and 6 degrees btdc
At the moment I have warmed up engine removed and plugged the vacuum pipe at tick over 950 rpm and lined up the 6 degrees timing mark.
Could some of you golf experts advice me if the vacuum pipe should be on / off
And what revs?
As too high mechanical advance would start happening
And what revs?
vacuum pipe off and plugged, 6 degrees BTDC for kjet engines
Reason you see both is for carb engines the dizzy vac line is left on, engine timed to 18deg BTDC
Re:
Thanks for that what engine revs would you recommend
just at idle for both, 950rpm will be fine. you can usually add a bit extra advance if you're runnign it on decent fuel
Re:
Many thanks for the advice
FYI… The set up mentioned above is if you are running on super unleaded which is this the best fuel to use to get the best out of the engine.
I believe that normal unleaded needs the timing retarded by 6 degrees.
