Advice needed from a new owner
(In Topic #130892)
I have noticed a few problems,
the first been when i start her up a red comes on and off a few times above the Temp reading, this also doesnt move up and i dont think i have heard the fan……thermostatic?
is it a bugger to a) get one b) change it?
But the main problem is it doesn't always start or does start then cut out,
when I rev it up and the revs seem to go high too quick and in first gear and it is always stalling, like the biting point is so small, you have to start off and careful really slow, not what i imagined from a golf…..any ideas on this one would be greatly appreciated,
Thanks in advance Baggie
If you can read this, thank a teacher,
If its in English, thank a soldier.
A soldier fights not because he hates whats in front of him, but because he loves whats behind him.
Not sure on cutting out, maybe search old posts re vacuum leak, should be a good place to start.
calico said
se if there is any adjustment on the clutch cable it may have stretched or the clutch may be fubared
Cheers mate have a look when I sober up tomorrow
Just got a new clutch cable and hopefully will get it on the ramps at work this week, failing that it will be a new clutch………..
the sensor was the temp gauge problem
trying to sort fan not working now as well
light stops flashing when engine started
