Advice / Help on 2.0 blocks to fit mk1 1.8 DX engine...2.1??
(In Topic #122556)
I have a Mk1 Campaign which has a C pack head and fast cam and 4 -2 -1 manifold etc.
The car is for all intents and purposes a std car to view and i dont want to change this.
Looking at doing the bottom end and wanted advice as to what 2.0 bottom end i need if i was to source a 2.0 block???
My intention is to take it out to 2.1 and then i figure the engine will the best it can be without changing it from its original set up/type etc…
The other idea of course is to have the current bottom end redone???
If anyone has had one done or knows what a 2.1 is like i would like to hear???
Your thoughts and knowledge would be greatly appreciated on this!!!
any info on this would be awesome!
1983 Mars red MK1 Wagen.
if you run the 2.0 8v on carbs or k-jet you need a dizzy adaptor ring from TSR, swap the 2.0 dizzy gear to the old dizzy and drop it in.
