2l conversion to a 1800dx engine head?
(In Topic #82839)
I have recently destroyed my piston on cylinder 4, so i am in need of help. I am looking to increase the size of the bottom end 2 a 2l, but don't know which bottom end will fit? I have been offered a 2E and an AGG bottom end but which one is better. My old head has had a bit of work done so would like to use this.
I have got another bottom end sitting in my garage but don't know the code, but it seems to have a water inlet going into it, and no where to put the warm up reg. but my head is the part that ha sthe watre inlet at the moment. Any advise would be appreciated.
o yeah my car is a 1800 gti 1983 with k jet
baby blue 1983 mk 1. 8v gti
You could go seek a 2.0l 8V engine - for example 3A which is found in Audi 80s, or 2E or AGG (found in Golf mk3, and I think Corrado/Passat too). This would make the conversion simpler. 3A is the 'bubble block' engine and is the same height as the original, so no real issues fitting it in. The 2E/AGG is taller, so things like exhaust manifold, bonnet touching throttle body, etc need to be addressed.
This thread is going to help.
The bottom end i have sitting in the garage has a black unit on the front where my warm up regulator should be looks like it is meant to have a sensor in it or something??? it is from an 8v and all fits together with my head. Am trying to get pictures to explain further.
Regards Volkswarren
3a 16v or totally naive
I am considering the 2 liter route too.
How much of an issue is the 16mm extra height for the throttle body? Everyone seems to say that these issues 'can be overcome'.
How can they be overcome??
And are there any other issues other than the exhaust manifold? Clash with cross brace, etc?
I'd like to keep the bay standard looking and get good tourque for drivability throughout the range. I'm thinking 2l with some mild head work, mated to a Mk3 Gti 8v box for reasonable cruising revs.
Thoughts / comments???
Huw
