1991 Clipper Engine Code?
(In Topic #207449)
EG?
I think that's a 1.6 engine.
Info from website.
EG 81 110 1,60 4 06/76-12/83 GOLF
EG 81 110 1,60 4 08/79-02/84 JETTA
EG 81 110 1,60 4 08/76-07/83 SCIROCCO
I found the info here.
http://vag-codes.info/files/engines/vw-engines.pdf
Again on this site a EG is a 1.6 from 1976 - 1983
http://www.clubvw.org.au/vwengines
Hopefully someone with a similar age car and carb can see what engine they have fitted??
What does it say on the log book? If someone has done and engine change they may of not changed the log book?
Just had a look through and I think it would of come out of the factory with an EX engine but not 100% sure.
if its on the passenger side between 3 & 4 then its deffo not an EG as the late heads dont fit early block
rubjonny said
EG is a MK1 1.6 GTI lump which is earlier type block casting/head. If it is an EG then the front coolant flange would be on the driver side between cylinders 1 & 2.
The front coolant flange is on the RHS Johnny just after the fuel vapour separator?
mark1gls said
Got a picture of the engine?
Standby Mark will get one tomorrow, thanks
