1984 Cabby Running issues
(In Topic #147905)
My 1800 gti decided not to start a couple of days ago, up until that point it had been running fine.
On closer inspection I found it had no spark and using the good old Haynes manual I did a few tests on the circuits and found the Ignition module was putting out too much voltage, in the manual it's meant to be 2 volts, mine was 8.
I purchased a new module and fitted it and now the car now starts first time on the button, but it won't idle. If i keep my foot on the pedel it runs ok, but as soon as it goes to idle it dies instantly. It doesn't caugh and splutter it dies instantly, the revs just drop to nothing and instant cut out.
I've got new leads and plugs which i'm going to fit tomorrow, but i can't beleive its them.
Any ideas guys?
1980 MK1 3 Door
1983 MK1 5 Door
Too many air cooled's to mention!
1983 MK1 5 Door
I'm begining to think the new module has caused this issue and maybe it's not compatible with my car.
This is all very starange to me.
1980 MK1 3 Door
1983 MK1 5 Door
1983 MK1 5 Door
was it a genuine part, id rather a 2nds hand vw item than a cheapo pattern part. mk2 golf ones fit fine
The car is now running ok with new leads, plugs, a coil removed from my MK2 Golf driver and the original module.
I'm going to put all the old stuff on my Mk2 and see if it works, hopefully this will prove there was a fault with one of these components, if not…….. I've no idea.
I let you know if and when it stops working again.
1980 MK1 3 Door
1983 MK1 5 Door
1983 MK1 5 Door
