1982 1600 oil is coming out from all angles
(In Topic #85550)
I have just got my hands on a 1982 1600 gti My problems are as follows…
The engine oil seems very thin and needs replacing but it won't drain from the plug I've tried running the engine without the plug in place but still no joy,
Oil also is coming out through the injection system and dripping from the air inlet near the radiator, The air filter was covered in oil!
Also the exhaust is dripping oil this can't be good!
On tick over a slight ammount of smoke comes from the exhaust but when the car is revved up a bit I have huge clouds billowing out much to the joy of my neighbours!
I'm not sure what fuel has been left in the car but I will drain it out and replace asap. What is the best fuel for this car?
You need to get some very old petrol.
Probably around 1970s stuff if you can.
As my grandfather always used to say, there's no fuel like an old fule
Ali Cabrio
PS - Otherwise take the sump off. Confucius say running engine with no oil is seriously bad idea
Mars Red 1.8 GTi Cabrio 1985
Seat Covers
Scratches
Leaky roof
1 million smiles per hour
Seat Covers
Scratches
Leaky roof
Oil dripping out of the exhaust means rings worn to death. Not good.
Clouds of white smoke out the back means head gasket gone
All three means you need a manual and lots of spanners.
Or a new engine.
Is the dipstick covered in mayo?
Ali Cabrio
Seat Covers
Scratches
Leaky roof
Seat Covers
Scratches
Leaky roof
I have drained the old oil was a mixture of oil and water certainley plently of it. Solved the oil from the air intake problem.
I still have smoke and oil from the exhaust though, No mayo on the dipstick was just very thin.
Do you think piston rings and head gasket is the only cause, Would old fuel in the tank cause problems, I know this car had'nt moved for about 4 -5 years before last week!
