16v kr and 16v pl diference?
(In Topic #130387)
And my friends PL engine have not. What is it ? which is better ?
Thank you
The main diference is that PL is catalitic, and have more smoother cams.
suppose you could not use a cat. kr cams on the pl and see how it goes.
both should have wur
Saab 93 diesel daily
Run's fine. It's basicly the same engine.possle said
think the use 9a cams which are "smoother" on the inlet as to not damage the cat.
I think the inlet manifold in the PL is 42mm and in the KR is 50mm, but i'm not shore. :wink:
swap a kr inlet cam into a pl, and you have a kr engine
inlet nothing to do with it, kr got both the 42 and 50mm inlet depending on the age of the car
