16v ABF conversion
(In Topic #136045)
16v ABF conversion
Can any one recommend a garage or private mechanic who can do this work for me.
As I'm no mechanic and don't have time to attempt this.
Also any advise on whether or not the ABF is a good
Choice ?
Dan
2001 Seat Inca 1.9 SDI (Weekday fun)
1982 Volkswagen Golf 1.6 GTI (Weekend fun)
Brace yourself for quotes of the work done, if you're paying labour - how much money did you have in mind?
multiply that by a garage rate, plus if you dont use a specialist it might take them longer to do it, order the wrong parts, mess up a few things and have to redo them etc.
RubJonny, do you only charge £10 an hour? That's a bargain. I'm looking at an ABF conversion for my 1.8 dx cabby in the short term (next 3 months) and am wanting advice on whether it'd be best to buy a full car - and basically drop the rear axle / front, engine, gearbox etc and everything and use the mk1 shell. Or just buy engine, ecu and manifold and do it that way?
I wanted to upgrade the brakes as they aren't the best and especially with the etc bhp, being able to stop is important hence why I thought of using most of the donor car.
Kev
trouble is i have no free time anymore, im churning out wiring looms nowplus my wife hardly ever works lates/weekends. couple years back she had to do it all the time so ihad lots of time to go out and help people!
no point buying a donor car as theres bugger all of use on it apart from the wiring, engine, box + linkage if you want cable shifter and the rear calipers n carriers setup. you can use the front brake calipers n carriers too if they're 280s with the adaptor kits off ebay though.
if you have the space though you could make money back breaking it, but it would depend how cheap you pick it up for vs just an engine, ecu and loom. personally id stick with an 020 box, unless you plan to go mad with the power later!
if you're willing to wait a while then you never know, this is party why I'm cheap i wont drop everything and work on it for days in a row, just when time permits. in the example above it took nearly 2 months to complete the project as the car was located pretty far away and i couldn't get down there every day. plus by the time i did get there i couldn't put in a full days work!
my post above was basically an example of how long it can take, to help the op work out what sort of money he is looking at if he takes it to a garage or wherever.
my hourly rate is stupidly low thats for sure,I really should charge more but im just a weirdo i guess
I'm sure you'll get it done quicker than i ever could these days if you're able to get good solid days work on the cars
i dont supply engines or anything though i just convert looms that are posted to me. as i say the loom conversions are getting popular i have 4 on the go right now with quite a few more coming to me in the future. so if you're on a short timescale i might not be your best option. i can of course take you thru everything you need to know to make the loom yourself, my service is really for people who are not happy with doing their own wiring
