1.8t sits to high
(In Topic #190739)
help please
Website Manager
I had this exact thing a few weeks ago. I was running epytec mounts, either side mounts were fine but the rear gearbox mount was the issue. Firstly you need the gti rear mount beam as the 1.3 is different( which you probably already know). You can get the 1.3 to bolt down but it pulls the engine back lifting the throttle body up towards the bonnet.
Then the second issue i had was i bolted the rear mount ( which i had to lengthen the horizontal plate by 2 inches) as i thought it should be fitted to the gearbox. It has 4 holes, so i expected them all to be filled so fitted it so. Turns out in my case, (it may be different in yours) if i bolted the rear mount to the beam and let the engine sit naturally only 3 of the holes lined up. The whole gearbox had moved up 1 hole on the bracket to where i fitted it before.
Bonnet now shuts properly with clearance, rear mount can be easily fitted without pushing or pulling the engine round and the passenger side driveshaft now looks straight.
Hope this helps.
