1.8 K jet vacumn pipes- where do they go?
(In Topic #135892)
Anyone give me a quick answer on what goes where? (to front or back of inlet) even better a pics…thanks
Thanks so much for help.
If so, back of throttle body to dizzy through a t piece.
Other branch of T goes to canister. If no canister, presumably no T piece.
From "2 nipple thingy" (1 way valve - they're pretty universal… especially if one of both are blanked - eg looks like a rover part'd fit!) 1's either blanked, or goes to a black sensor that floats on the vac pipe, then that's blanked. The other goes to a capsule that looks like the one on the dizzy on the front corner of the metering head.
That's how it is on our late cabby with a JH
when i do it i put the dizzy vacuum on its own nipple and others T to the other nipple, but thats just me
There is a vacuum inlet on the back of the intake manifold - this goes to the dizzy.
Then on the brake servo vacuum pipe there is either 0, 1 or 2 inlets. These go to the WUR and the MFA, like I say though you may not have any other vacuum ccts other than the dizzy (I don't on mine).
To invade!
It's correct about the vac inlets tho isn't it?
tbh it doesnt matter as long as its a good vacuum it'll be reet
