1.8 gti smoke??
(In Topic #162706)
thanks in advance for any help.
Head gasket, new piston rings head pressure tested. new main bearings, new big end bearings.
Each time taking head off.
Turned that between the top of the valves and under the rocker cover sits an oil deflector.
It stops excess oil getting back through the breather.
Cost 50p from a scrapyard!!!
They have them listed at VW heritage as part number 026103547 theyre a fiver, got to be worth a try!?……..
This can weaken the rings by tempering them and making them less springy.
Cero said
If good compressions then you could be looking at valve stem seals or worn guides, unfortunately it's a head off job to check.
hello all, sorry to disagree but you can check guides for wear and obviously change valve stem seals (with the right tools) with the head in place.
Personally I think you need to make sure you have the splash guard fitted because without it you will be burning fumes
Do it once and do it right! ok, we've identified the problem, lets not make it worse by guessing……… Identifying the sympton is not the same as understanding the cause
Totally agree with you, but have you tried it
It's a nightmare to do in-situ even with those tools.
cushx you need to remove the valve cover and check to make sure you have a splash guard fitted before you do anything else bud
my question is "do you have a splashguard?"
so i take it youve already had the head off? it really needs checking with an engineers edge to make sure its true.
I also have to assume you have a torque wrench too? preferably calibrated, and all the relevant technical data for re-installation of the head?
Please forgive me but I often hear stories when people dive in and make everything worse for themselves
I understand you having too ask i know people that try to do the jobs without the tools
guide check and stem seals all round then i reckon, be quick before we loose the sun!
