1.8 GTI gas flowed cylinder head
(In Topic #83760)
it probably is running a little lean and expect it could do with a tweek on the metering head to get a little more fuel in there
that's as much help as I can be though I'm affraid… my Mk1's been running slightly rich for ages no matter how much I adjust it I can't get it right!
Hi and welcome to the club racinsnake. got any pictures of your Mk1?
9A,027,278,02A,mikuni r1 carbs,megajolt 36-1,R1 pump,lc1,02J shifter,9J ats…
failing the timing, check fuel pressure.
took it up the track and kept backing the dizzy back untill it pinked, then touched it forward untill pinking stopdd! upd the fueling! and it boosted like there was no tomorrow!
hth
simon
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
mk1 cylinder headache
Have you checked your vacuum advance? Could be this.
Injectors should fit ok. You can get new injector holders (the bit that the injectors push into that screws into the head) from vw. Did you replace the injector seals? Should do this when removeing/replacing the injectors.
Jay
