1.8 GTI Cabrio, Running pants when warm..
(In Topic #94252)
My GTI runs awfully, almost undrivable when warm. strangley it drives fine for around the first mile(ish) then its starts juddering not like its miss firing (firing on all 4) but its not like firing properly after around 30x revs and struggles to pass 40mph. The engine also stalls when approaching a junction.
i've replaced the cap, rotor arm, leads, fuel filter. was advised to change the fuse box which i thought was orginially causing the trouble as the the connection had 'broken' down.. i've thought about engine timing but i havent interferred with the dizzy and doesnt add up with the cool temp running..
I'm baffled so any suggestions welcome!
Thanks,
Chris
Have a look at this link friend ……
Also then see …..
Domain parking page
Start with the simple parts .
Cheers ………….
pasted from it is this lot
Symptom: Irregular idle during warm-up
Cause
Remedy
Leaks in air intake system (false air) Check air system for leaks
Auxiliary air valve does not open Check valve for correct function
Cold start valve leaking Check cold start valve
"Cold" control pressure outside tolerance Test pressure
Injector leaking, opening pressure low Check injectors on tester
Injected fuel quantities unequal Check for equal fuel quantities
Basic idle setting incorrect Check and adjust CO level
Lambda control system not functioning correctly Check Lambda control system
top
Symptom: Irregular idle with warm engine
Cause Remedy
Sensor plate and/or plunger not moving freely Check for free movement
"Warm" control pressure too high Test pressure
"Warm" control pressure too low Test pressure
top
Symptom: Engine will not accelerate, backfires
Cause Remedy
top
Symptom: Engine backfires under load
Cause Remedy
Electric fuel pump not operating Check pump fuse, pump relay and pump
Primary system pressure out of tolerance Test pressure and adjust with shim
top
Symptom: Poor Performance
Cause Remedy
Throttle butterfly does not open completely Check butterfly and stops in throttle venturi
