1.8 GTI 8v engine with Kent Cam
(In Topic #181062)
I am currently doing an engine conversion on my mk1.
The engine I pulled out a year ago is a 1.8 8v GTI from a mk2, it is fitted with a Kent cam. It pulled really well when it was fitted.
What do people think this is worth? Would I be better stripping the Cam out and selling it with the pulley by its self, seen these go for like 80quid. Then scrap the rest of the engine. Or maybe just take the head off and sell it as a modified head.
Any help would be great.
Craig
which makes it an EV
sorry
if you could find the head casting part number for a hydro head that might help.
may as well check anyway, buy a rubber gasket repair kit (with studs) worst case you'll probably fix a slight seep, best case rubber gasket can be reused if you take the cover off only a few days/weeks down the line
Will the head need to be removed to fit cam?
Last edit: by cabfan
