1.8 DX Sump gasket
(In Topic #201401)
Would appreciate confirmation that rubber is the way to go!
Good luck with the 2 bolts near the gearbox as I found them a real pain to get them back in straight as they kept on going in on an angle. I fitted them 1st then worked my way round the sump.
Having not taken off the old gasket yet I dont know what gasket if fitted at the moment - paper/rubber.
I've never come across a rubber sump gasket on a VW before.
Many thanks for advice!
Many re-use the original bolts without issues, but VW obviously thought that the extra thickness meant the bolts weren't quite up to the job. plus as I say, you can take the opportunity to get a set of allen head bolts which are much easier to put between the sump and box
Thansk for the info
You just have to pop the oil pump out to fit it. Luckily I was planning to check the backlash etc anyway…
VW Part number is 037 115 220 B if anyone wants one, should set you back about £30ish. The advantages are in limiting surge and reducing the windage cloud - basically keeping the oil at the bottom of the sump physically separated from the rotating mass so less energy is wasted splashing the oil around the walls of the crankcase. In theory you can run higher RPMs too, but I dunno how much difference it will make in practice. This engine will be a bit of an animal anyway!
Also means you don't have to replace the sump gasket when you take it off
Stone
"Klaus": 1987 Clipper Cabrio, LA7Y, 1.8 Weber (auto)
1995 Corrado VR6, LK4Z: RIP
2003 Golf R32, LB5R
2003 Golf R32, LB5R
