1.8 8v starting problem
(In Topic #118111)
when running to start with the throttle doesn't want to work it sounds as if it runs on 2 then 3 then when the 4th kicks in it revs freely but take your foot off and it will want to die again.
when finally running it has very little power and when tryin to pull away will stall unless reving very high. after a couple of miles drivin and there is soe hat in the engine it is fine.
any sggestions would be great im thinking possibly 5th injector??
cheers rob
