1.8 8v GTI TDC Question
(In Topic #91829)
hi
Dly49 said
( maybe someone did a fly wheel oil seal and put the fly wheel on upside down?)
The bolt pattern isn't a regular hexagon, one of the bolts is offset. They'd have had to do it and miss out one of the bolts! Have you rotated the engine through a full turn, looking at the marks on the top of the flywheel (take out the entire plug at the top of the bellhousing, and use a torch). I suspect you're seeing another mark around 180? fron TDC, on the flywheel - maybe someone put a mark on it?
