1.8 8v GTI over-revving, possible inlet?
(In Topic #124280)
My sis is having a few issues with her Mk1 1.8 8v GTI cab ('87 E plate) over-revving. I assume there's an air leak somewhere although can't see any obvious signs. She also mentioned she can smell fuel.
I have been told it's a common problem with the inlet manifold on these. Is that correct? I can't see it myself as an inlet manifold is a pretty solid thing, but over-revving and stinking of fuel does kind of sound like inlet.
If it is the IM, is it likely to be the same as a MK2 1.8 8v GTI one? Seen some of them available but none specifically for her car.
Cheers,
Rob.
Self converted Corrado R32. I will own a Mk1 as well one day!
Porous inlet manifold is a very rare fault but there's plenty of gaskets and pipes off it which could leak, especially old rubber pipework which degrades etc.
Mk2 inlet manifold is different.
Ahh I thought it might be different but just wanted to check, cheers!
jaycab said
squeese the AAV to see if the idle drops,if your not sure what it is have a searcharound the site and you should find it,
Cheers, I'll give that a go. If the idle drops when squeezing it then I'm guessing it's stuck open or something letting air in for cold start? How much is a new AAV?
Also worth mentioning, it's smells quiet rich. I didn't know whether it would be sticking on the cold run causing it to overfuel and idle high all the time? Is this measured by a water temp sensor in the stat housing like on my old VR by any chance?
jaycab said
all cars run the cold start of water temp
The Mk1 Golf GTI alters the mixture during cold start and warm up by the warm up regulator. This gradually gets heated by thermal conductivity from the engine block and an electrical element (no coolant connection). It alters the control fuel pressure, which alters the mixture.
The only reliable way to measure mixture is with a gas analyser, so don't do anything too rash (like replacing the WUR!) without at least having a good idea if its wrong or not.
Rich mixture can (& does) cause a higher idle than a weak mixture, but check the air flow (eg aux air valve) first. If the AAV is stuck (either open or closed), you'd in fact see low idle speed at cold and higher idle speeds once warm, since its not varying the airflow (increasing for cold start and warmup).
yes paul but all run cold start from water temp……….warm up is not cold start.paul_c said
You also suggest the aux air valve is faulty, which also operates in the same way as the WUR (senses temperature from conduction and has an electrical heating element in it).
The only component which senses coolant temperature and affects fuelling is the Thermo Time Switch but its clearly not at fault in this scenario. Even if it was faulty, the circuit with the TTS and 5th injector (cold start injector) is powered by terminal 50 on the ignition, which is only live when the starter motor is turning, so its isolated from running except during starting. And if there was an electrical fault or miswiring which meant the 5th injector was constantly firing, it would flood the engine so it didn't run. So its irrelevant to the original poster's running issue.
Anyway, probably best to await any update from the OP on this one.
Member 125 - 2005
