1.8 16v kr slow acceleration
(In Topic #157163)
I still have to replace a core plug and it needs an oil change so dont know if either ofthose two affect it?
And im still yet to fit the overun cut off valve and vacuum switch. Are sorting these things likely to fix this problem or should i be investigating elsewhwere?
http://www.vwgolfmk2.co.uk/viewtopic.php?f=37&t=25972&
So have had another look at things today, and its safe to say the whole thing is absolutely air tight. So im sure no probs there.
Leads are all in correct order
Vacuum switch is now wired up, but not sure if thats made much of a difference. Over run Cut off valve is plumbed in just not wired up yet.
So i thought id go over my symproms just to clarify if it definitely sounds like i need to spend more time on getting it tuned right.
When i start up engine from cold its very rough (will sometimes cut out) but as it warms up it smooths out and idles at around 950 with no visible rocking or any struggle.
The problem seems to be if i put pedal to the floor it has a delay. from what i see its almost as if its slow to creep up to 1500 but as soon as its over 1500 it shoots up fast.
Does this still sound like its not timed correctly? or is something perhaps at fault?
Sorry for essay!
Figured out that the crankshaft is out of sync by almost half a turn to the cam. No ammount of tweaking the dizzy will help that! Lol
Im assuming this is why im having loss of power?
Is it as simple as im thinking it might be, that i can remove cambelt and manually turn crankshaft to bring the diamond inline and it then being synchronised with the cam?
but double check the crank is at tdc when the punch mark is lined up, it could be someone bolted it onto the crank wrong! shine a torch down spark hole #1 and look at the piston, or put something like a long thin dowel down the hole while you carefully turn the engine over. when its right at the top check the flywheel and crank pulley marks to see if they're anywhere close
